houser avatar image
houser asked
Node Red - "current active alarms" via API?
Looking for "current active alarms" if that data is in there?
Is it in the VRM API node : Installations / Get alarms?
I am getting a "0" as payload now. Will it give me a number of active alarms when they are active? Many thanks
VRMNode-REDapidashboard
Fideri avatar image Fideri commented ·
Also interested in your question. Using grafana, I couldn't find all the system alarms. I have to specify a particular alarm.
F.
houser avatar image houser Fideri commented ·
Ok, thanks for that also. I assume one might be able to build something in node red that does this. I want basically something similar to what VRM does when it says " 2 active alarms" but in Node Red.
Fideri avatar image
Fideri answered ·
I use diagnostic data from the API. Because the "positions" of the data changes randomly, I use certain phrases (those have never changed) to filter the data. If you need that, let me know. I have to clean up the script first as it's written specifically for my install.
F.
houser avatar image
houser answered ·
Thanks @Fideri
I would be interested in your script if it is not too much work, as I don't know what it does..
I ended up creating a dashboard with a number of text fields to get started and get a grasp.
Fideri avatar image
Fideri answered ·
@houser
Not sure what happened there. I was responding to a totally different question which has now disappeared! Anyhow, I will just share the script.
F.
houser avatar image
houser answered ·
Thanks again @Fideri
I figured out my other question so was trying to be quick and clever and deleted it, as there was no answer yet. Sorry about that, Appreciate you sharing your script!
