jmynier avatar image
jmynier asked
100a or 32a autotransformer?
Can someone tell me what the 100a autotransformer is built for vs the 32a? I'm just trying to run a 240v mini split from a 120v charger/inverter. Wasn't sure if the 30a or 100a is suitable or inverters or if one or the other is more suitable for generator power. I'm only using solar and grid, not generator. Thanks
Autotransformer
Justin Cook avatar image
Justin Cook answered ·
It's genuinely all in the name - the 32A can handle 32A 240v feed through current, while the 100A can handle 100A of 240v feed through current.
Unless it's one hell of a mini split I can't imagine it'd be pulling more than 32A, but only you or your electrician can determine that for sure.
https://www.victronenergy.com/upload/documents/Datasheet-Autotransformer-32A-and-100A-EN.pdf
