robster avatar image
robster asked
Can an ET112 feed two Cerbo GX controllers?
Hi All,
I currently have a single phase house (UK) house running a 24V Multiplus ll as a purely ESS system with no connections to the AC Out side of the inverter - with an ET112 measuring grid in/output
I am planning on adding another completely separate ESS system in an outbuilding on the same phase using a 48V Quattro ll, again with no connections on the AC Out of the inverter.
Is there a way to use the data from the ET112 to feed info to both Cerbo GX units, or will I need to fit another ET112 for the second system?
I realise that I will also have to connect them in such a way that they don’t see each other as a load and try to charge each other’s batteries.
I’ve trawled the internet & forums but can only find info and wiring diagrams for inverters in parallel, with a single Cerbo GX operating in master/slave mode.
Thanks in advance,
Rob
multiplus in parallelQuattro-IIet112 pv readings
