davidtudor avatar image
davidtudor asked
Phase Missing After Generator Stops
Hi
i very intermittently get Phase Missing fault, this is a 3 phase system with 3 slaves also, Multiplus ii 5kva, all exactly same units all on same software.
I lose electric for a small amount of time and then boots back up, sometimes happens after generator has been charging and then stops as the charging is up to level.
3 phase
@davidtudor
Have you physically see which phase it is that is doing it? That usually narrows down where the issue is.
Error 17
davidtudor avatar image davidtudor Alexandra ♦ commented ·
HI
no, I haven't I presume it will show you by the lights on front, the problem is its so quick at restoring, I cant catch it, one thought I had was to put CCTV camera in there pointing at the Multiplus?
