billk avatar image
billk asked
Correct way to route the rj45 cable between two Quattros in parallel
May seem silly but I am trying to do a great job on this installation so I want to run all my cables neatly. I need to run the rj45 cable between my two Quattro inverters and there is no designated port for them to be guided through. I can't find any information or photos anywhere. Do I run them out the compression fittings that are used for AC In and Out or do I run them out the white fitting? Or some way different I'm not even aware of?
battery charging
Hi @BillK
Both work:
-if you have unused cable glands you can use those, the RJ45 connectors fit through it.
-you can also use the big opening for the DC connections, there is a little notch in the 'devider' PCB between AC and DC side where you can fit the cables
