Is there a way to connect a bluetooth dongle to the CCGX, thus enabling the following of the CCGX from an Android phone (accurate amps and volts in real time, etc.).
Thank you.
Thank you.
No, a Bluetooth connection to the CCGX is not currently supported.
But the CCGX is available in VictronConnect when it is connected to the same local network with a wifi adapter, or through the Ethernet port.
11 People are following this question.
