I have 12/1600/70 multiplus compact, serial: HQ15522TZB4, firmware version is v159, victron connect app needs v415 for compatibility, is this upgrade possible?
thank you
thank you
You need to remove the front panel to check the number on the chip on the main PCB.
If it starts with 18, 19 or 20 than your Multi has the old CPU and can't be updated to 4XX, the highest FW you can install there is 209.
It needs to start with 26 or 27.
https://www.victronenergy.com/live/updating_firmware:updating_ve.bus_products
The number on the chip starts with 26, but App Victron Connect does not notify the update.
Can you help me?
You need to use VEflash
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
51 People are following this question.
