michaelsamer avatar image
michaelsamer asked
Multiplus II Upgrade Keys
Hi
as tomorrow my Electrician is delivering and installing my new Pylontechs US5000, I prepared to update my MP IIs to a newer firmware (as 465 is too low to cope with the US5000). When doing so on my first I was greeted with a Key challenge.
I tried the other two as well to ask just in one call for an upgrade key:
MultiPlus_L1_
Target key: 318F-007A-0100-450A-8A5A
MultiPlus_L2_
Target key: 968F-007A-0100-450A-EF5A
MultiPlus_L3_
Target key: 2C90-007A-0100-450A-865B
Can you please deliver the keys (hopefully all three will ask the same Target keys when switchced on again...)?
What is the reason behind the key challenge?
Cheers
Michael
firmware update
Where/How you do the update? Can you make some screenshots?
I never saw something like that.
Easiest way is to use VictronConnect (all setting will be reset to default!):
https://www.victronenergy.com/media/pg/VictronConnect_configuration_guide_for_VE.Bus_products/en/firmware-updates.html
Duivert NL avatar image
Duivert NL answered ·
Never heard of that before also…
michaelsamer answered ·
Hi Matthias
I wish I did as I could not reproduce the Key challenge. I restartet VE.Flash, chose the same flashfile (MultiPlus_II_2629_Firmware_2629552.vff) and retried it on all three MPs and worked like it should....
Strange but maybe because of the old basis (465....) anyway worked and resetet as usual to defaults after flashing.
