Can someone post the release notes for v552?
I feel like I shouldn’t have to make a separate account on Victron pro just to be able see what’s new with the firmware update.
The thing is if you want to be doing something a professional would normally do, you need to get the professional feed for information.
Anyway. There has been a product application modification change and high chances it does not apply to your set up.
Victron Professional is more than just the changelogs.
You also get news about new products/features, there are tutorials and webinars.
Updating firmware is a professional feature? Seams like it would be easier to put a details tab under device list in vrm where we already see the updates and is would show the details.
"Never change a running system"
Unless you have problems there is no need to keep everything up-to-date.
Rarely there can be a problem during the update via VRM and then you should know what to do to get the system running again. That's why it is not recommended to update a perfectly running system.
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
53 People are following this question.
