dennison-p-pulgarin avatar image
dennison-p-pulgarin asked
EM530 setting PN EM530DINAV53XS1X
It's the fisrt time using the energy meter, not sold by victron, I have to set and connect i would like to confirm a couple of thing.
To connect EM530 to the PC we can use the RS485 to USB sold by Victron, the connectio should be the same when we connect to the Cerbo.
to set up the EM, we have to modify:
· Electrical System - current transfor - primary and secondary
· Metering - DMD calculation - to 1 min
· Communication - Active - baud rate 9600
the last point is where i don't if i can to change something more.
thanks you for your help
Energy Meter
