sircasper avatar image
sircasper asked
Adding Cerbo GX to existing DMC 200A GX with Multiplus Compact 12/1600
Hello, I'm currently having a simple setup of a Multiplus II Compact with a DMC connected thru ve.bus RJ45 connection. I want to add my Cerbo GX to that configuration. Question: since the DMC has only 1 ve.bus connection, I wanted to know if I can disconnect the ve.bus cable from my DMC and connect it to the 1st ve.bus connection on the Cerbo GX and adding a second RJ45 cable from the 2nd ve.bus connection on the Cerbo GX to the DMC ve.bus connection?
cerbo gxmultipluss iiDMC
Cerbo GX product page
GX family product range
Cerbo GX & GX Touch datasheet
Cerbo GX Manual
Venus root access document
DMC Product page.
DMC Online manual
