ertcom avatar image
ertcom asked
Multiplus IIGX Firmware update failure
Hi Community. Attempted to update MPIIGX firmware from 510 to current version remotely. I do not have the MK3 USB. The GX device is running v3.33 and I can see it on VRM. The Unit will not switch on. Display Status = OFF. I can communicate with the GX remote console but it does not detect the MPII anymore. I have tried switch and disconnected from battery/grid to reset but will no start. Advice appreciated.
vrm firmware update
ejrossouw avatar image ejrossouw commented ·
Can you see the MP in the VRM firmware update device list? Have you managed to upload the settings file you downloaded and converted via ve remote configure?
ertcom avatar image ertcom ejrossouw commented ·
The config file downloaded but the MPII is not visible in the device list in VRM so I have not been able to upload the converted config file. The firmware must have corrupted. The MPII displays shows the unit booting but then remains in OFF state.
Alexandra avatar image
Alexandra answered ·
@Ertcom
You are going to need the mk3 if none of the above restores it to being recognised.
ertcom avatar image
ertcom answered ·
Thanks Alexandra. I have ordered the Mk3 and will report back.
ertcom avatar image
ertcom answered ·
I was able to load new firmware and the .vsc file to the MPII using the MK3USB with VEConfigure. The device may have a hardware fault which could be why the remote update failed. It seems to go into a reboot loop (about every few minutes) where the GX device loses communication with the MP (it disappears from the device list in the GX). I can also see it rebooting on the MPII display. Seeking advice.
