2mas avatar image
2mas asked
Cerbo + 3 x Quattro Remote issue
Hallo
I got 3 x Quattro running 3 face - all good there
Then I have a Cerbo connect via VE.bus - all good there
I’ve have a PLC running as well - want to use the remote on the Quattro to turn on the inverter, I connect a relay from the plc to shorten the remote “com” and “on”. Okey et turns on, but when i want it “off” it turns off but short after it turns on again.
I think it’s the Cerbo that turns it back on.
Can I disable the “Cerbo remote function” -
So the Quattro is “stand alone” but I still can read data like load on the GX touch ?
Thanks for your input
cerbo gxmultiple invertersremote start
