davehammer avatar image
davehammer asked
Orion charger floats too quickly
I use the Orion to charge camper batteries from truck alternator/starter battery. 2005 Toyota Tundra, Orion 12V/12V-18A charger, two 100 AH LiFePO3 batteries in parallel. In a driveway test, with batteries needing charge, I get 1 minute of bulk, 30 minutes of absorption (adaptive absorption on with 2 hour max), and then float before batteries are charged. In the driveway test, it went from absorption to float with input/output voltages 13.3/14.1. When driving I get less absorption, with and without adaptive absorption time. Without adaptive absorption, I set absorption time to 2 hours, but got only a few minutes of absorption. I also tried a driveway test, engine off, hook up 6A battery charger to truck starter battery, got 10 minutes of bulk and 3.5 hours of absorption (in/out voltages 14.1/14.2) before I stopped test (camper battery slowly charging). This battery charger test seemed to work, so are the alternator and Orion incompatible and if so can it be corrected? Thank you
chargeralternatorfloatorion
Chargers.
