borgnix avatar image
borgnix asked
EV Charging Station System Data Error nach Update
Hallo,
EV Charging Station nach FW Upgrade " SYSTEM DATA Error " am Display Sonst funktioniert alles. was tun ??
Nochmaliges Updaten - kein Erfolg
Anderes Gerät - nach Update gleicher Fehler
Bitte um Hilfe - Danke Peter
ev charging station
Hi, can we switch to English, and I will try to help. Can you give me the VRM portal ID?
borgnix answered ·
Hello Yes no problem
borgnix answered ·
Hello - unfortunately no change
difi avatar image
difi answered ·
Hello Lucian,
the update makes me crazy. Victron says everything is OK but I just can't get rid of this “system data error” message. I have already tried downgrading and upgrading. Also installed the firmware twice in a row. None of this has helped, I can't get a colored display. Is there possibly another procedure? If not, I will probably have to claim the new wallbox (with display) as defectiv
you are writing in 2 places? You have my answer on the other place.
wwet avatar image
wwet answered ·
Hello! I also have the same problem with the wallbox! The screen restarts every 3 seconds - in between the message "System Data ERROR" appears. The latest firmware (128-C25) was installed. Please help, thank you!systemfehler-evc.png
