paul1980 avatar image
paul1980 asked
Using Cerbo GX with Multiplus 2 GX
I am looking to see what is required to connect a multiplus 2 gx to a cerbo gx.
I had a multiplus 2 gx already and then decided to get a cerbo so I can add functionality such as monitoring my water tanks in the motorhome. I am assuming that I can't have 2 GX devices connected together but I'm not 100%. I read somewhere else that you can unplug the gx device inside the multiplus but wanted to see if that was needed. Also if that is the case, how do I identify what I need to disconnect?
Cheers,
Paul
cerbo gx
Duivert NL avatar image
Duivert NL answered ·
Yes you must disconnect the gx card in order for it to work, see this post for explanation
https://community.victronenergy.com/questions/147860/disconnect-internal-gx-card-on-multiplus-ii-gx.html
paul1980 avatar image paul1980 commented ·
Thanks. So just to clarify, is the GX card the card the display ribbon cable is coming from? My Multiplus looks slightly different internally to the ones pictured.
Cheers,
Paul
Duivert NL avatar image Duivert NL paul1980 commented ·
Yes should have display, rj45 and power wire connected to it
paul1980 avatar image paul1980 Duivert NL commented ·
Great, thankyou for your help
