Hi! I am measuring DC 900mA intake current in Off mode. Is this normal? The battery will be empy soon with a power consumtion of 10W in Off mode. Can this be correct?
Thanks and Cheers. Steffen.
Not normal! I'd say typical draw in off mode is under 1 mA, possibly well under but never measured it.
The reason I say this is because when you disconnect the battery in off mode it takes 10s of seconds for the voltage held by the capacitors across the DC input to drop.
Thanks a lot, Kevin,
for your quick reply. So what shall I do?
I lost 7.2Ah over night :-/
The battery is directly connected to the Multiplus and the current drops to ZERO when disconnecting.
Is this a device failure? Shall I RMA the device to VICRON? Its brandnew and has just been unboxed...
Thanks again! Steffen.
40 People are following this question.
GX Error #48 DVCC with incompatible firmware- Old Multiplus
99% Offgrid - looking for charger for 48V batteries on multiplus II
Multiplus 48/800/9 how to use PV-controlled charging or ESS without feeding to grid ?
Issues with Victron set up in a Van after inactivity
MultiPlus 12/3000/120-50: Charge only until 90% setup possible?
