mikenr avatar image
mikenr asked
Quattro remote switch behaving oddly
I have a Quattro 48-10000-140 inverter for my house that is 100% off grid. Our bedroom is above the inverter and we like to switch it off at night. I want to use the remote switch to make it more convenient to switch off at night - eventually I discovered where the connection is, to wire in a 'normal' switch. I removed the jumper wire between the centre and left connector and put a switch in the position of the jumper wire.
I have the inverter on and my switch closed. I switch the inverter off with my switch and the inverter switches off - BUT only for about 17 seconds, then it switches itself back on for 8 seconds and keeps cycling until I switch my switch back to 'ON' and then all is normal.
Can anyone help?
Many thanks in advance!
remote console
5 comments
mikenr avatar image mikenr commented ·
I forgot to mention that I have the latest firmware uploaded to the Quattro - I checked that.
@mikenr
Maybe the resistance of the switch or connections.
mikenr avatar image mikenr Alexandra ♦ commented ·
OK, I will try another cable - I also tried just twisting the wires together to see if that worked (wires are 0.75mm2) and had exactly the same result :-/
Alexandra avatar image Alexandra ♦ mikenr commented ·
@mikenr
What inverter do you have exactly? Are you using H?
The photo I have of my H connection is rather fuzzy, but good enough to see what's going on. . .
