I only have one Assistant loaded in my Multiplus configuration, that is VE-Bus. The remote console display shows 'Hub-1' in the system box. Is this expected even though I don't have the Hub1 Assistant loaded?
Hi @Tim Chapman
sorry for missing this question.
What exact assistant do you have loaded, and what unit are you using / what firmwares on Multi / GX?
Thanks for the answer. The only assistant loaded is the VE.Bus BMS. The Multiplus is a 12/3000/120-16 firmware version 465.
The Octo GX is firmware 2.42
11 People are following this question.
