kww511 avatar image
kww511 asked
Solar or alternator charging. Either… not both at the same time
I have a set up in my caravan where I want to charge my house (100ah lithium) battery via a single Anderson plug on the draw bar.
I want to charge the house battery either from the vehicle alternator or a portable solar panel. NEVER both at once.
I will simply connect the draw bar plug to an anderson plug on my car (which will be connected to the vehicle 12volt system) whilst driving.
When parked, I will connect the draw bar plug to the portable 160w solar panel.
In the past I have used a Ctek D250se charger successfully utilising the solar input only on the Ctek unit.
Is there a Victron unit that can accommodate this scenario using only one of these input sources at a time without having to have two separate plugs at the draw bar??
battery charging
