hasen-kaninchen avatar image
hasen-kaninchen asked
MPPT 100/30 - Battery off??
Good day,
My Bluetooth MTTP 100/30 tells me that the battery is "off". What does that mean exactly?
The battery is connected as usual and works just fine. The charging does not though...
Thanks for your help!
battery charging
Justin Cook - Bay Marine Supply USA avatar image
Justin Cook - Bay Marine Supply USA answered ·
@Hasen Kaninchen, double-check that the "Charger Enabled" option in your VictronConnect app is switched on. To get there, open the app, connect to your device, click the gear at the upper right corner, then click the "Battery" section.
Hopefully that solves it. If it doesn't, then we need to start looking at the connection between your controller and the battery (ie, cabling, fuses, etc.), but check the charger function first and get back to us :)
