How do I use the second input of my multiplus which charges 4A, and let it only work if there is shore power and the multiplus is in charging mode? Can I program this via the relay port?
Regards,
goon326
Regards,
goon326
Do you mean Output?
If so look at the relay assistant and see if it can do what you want.
You cant control Multi relays any other way, not even node red.
You can use an input and make a relay follow it, with the assistant, but if you were using, say a GX relay, to drive the input, you would be better just using that relay directly.
Either way, switch a contactor, or bigger relay, that connects the output to your battery.
If you can run Large OS it will probably be easier to build your logic in NodeRed that and use a GX relay to switch the contactor.
I built you a PDF explaining, I am trying not to smoke so the distraction was worth the effort.
I don't think you will want charging state BYW if AC is on and the battery is full and in an Idle state that probably will not keep the relay on.
Hope that helps...
Thanks a lot! This will help, I will look at it tommorow, if I can built this!
42 People are following this question.
