tom-berger avatar image
tom-berger asked
which BMS in DIY battery will work with Multiplus2GX?
I am in the process do build a DIY LiFePO4 Battery (16s, 280Ah) which should feed a Multiplus 2 GX. I have seen from various posts that the widely used Daly BMS will cause a lot of trouble in connection with the MP2 or the Cerbo GX. Which BMS can be recommended for use with the MP2GX?
Thank you, Tom
Multiplus-IIBMS
jeanmarie avatar image
jeanmarie answered ·
Any BMS claiming a successful communication protocol with Victron environment will work (unfortunately I don't think Daly is one of those), you can go for Seplos, JKBMS or others
But be aware that using such a BMS, not validated by Victron, will cause Victron staff not even responding to any question or problem you may have with their HW
Sten avatar image
Sten answered ·
You could start here to see if there should bee a bms you could use.
https://www.victronenergy.com/live/battery_compatibility:start
for my self I use REC bms and it work like a charm. It is a litle hard to configure but I have made a xcell to calculate some off the values.
https://community.victronenergy.com/questions/145991/spreed-sheet-for-calculating-cvl-on-rec-bms.html?childToView=173614#comment-173614
tom-berger answered ·
Thank you for your input, but meanwhile I found a solution which enables to use most BMSs with Victron GX. It's a driver for the Venus OS, made available by Louis Van Der Walt over GitHub: https://github.com/Louisvdw/dbus-serialbattery.
There are some interesting YT videos showing how this works, i.e. https://www.youtube.com/watch?v=sHIlP2oJ3DU
