No acces annymore to Node-red via VRM. Link doesn't open. Was working in this space this morning and suddenly stopped the connection.
Reason ? How to solve this ?
If I browse directly to ipadres:1881 then i get this feedback :
Normally Node-RED can be found on this location. It either is starting and will show after a refresh, or it is not enabled in menu. More information on Node-RED on Venus can be found here.
I have the same kind of issue, node-red is constantly disconnecting, sometimes unreachable. It started around May 11th.
Sometimes a reboot helps but only for a limited time.
I am on the beta firmware v3.40~13
starting node-red in safe mode it returns:
Error: remote installation does not seem to have a running Node Red service.
Is this related the beta development of the new GUI?
Any fix to try?
Thanks in advance
57 People are following this question.
