semlohnhoj avatar image
semlohnhoj asked
Feature Request: "Disconnect AC input on SOC" under AC input control for Multi RS
The Multi RS Solar has conditional AC input conection settings that allow the input relays to be dissconnected and only connected when there is a sufficient output load or the battery SOC drops below a set percentage or voltage drops below a set value.
The disconnection can be set for when the output load drops below a certain load or the battery voltage raises above a certain level HOWEVER the option to disconnect on battery SOC is missing from the settings options :(
Under "Battery Conditions" the options for "Disconnect AC input on" are:
"Bulk Finished"
"Absorbtion Finished"
"Battery Voltage"
can we add "Battery SOC" please.
Multi RSac coupling
