lifewithmike avatar image
lifewithmike asked
Multiplus's in SplitPhase (Master/Slave) w/ Neutral Forming Transformer on EnPhase
I have a EnPhase system which operates at 240v L to L and when it goes off grid, it has a neutral forming transfer which gives me my L1/L2 to N of 120v. I'm adding an Victron setup to my existing setup and was wondering if having two Multiplus's (Master/Slave) for SplitPhase setup will pair fine with the existing neutral forming transformer. Alternative is to do a 230v Victron and run at 240v/60Hz which basically will be the same as the Enphase Micros run since they don't have neutrals natively.
Can two multiplus's in a split phase setup get harmed with a neutral forming transfer?
Multiplus-IIESSsplit phase
