Multi 5000 suddenly stopped working, low battery light is on but batteries are over 50 volts. Fuses seem ok Anything else I should check?
Guessing 50v isn't a cut off in any of your settings? I'm not so familiar with BMS controlled systems but is yours BMS controlled?
Any clues in gx device notifications or VRM alarms?
38 People are following this question.
GX Error #48 DVCC with incompatible firmware- Old Multiplus
99% Offgrid - looking for charger for 48V batteries on multiplus II
Multiplus 48/800/9 how to use PV-controlled charging or ESS without feeding to grid ?
Issues with Victron set up in a Van after inactivity
MultiPlus 12/3000/120-50: Charge only until 90% setup possible?
