I searched the product I have with serial number but the model on the result page were different from what I have.
The model I have is 12|12|30 Non-isolated DCDC charger but the result page showed 24|12|30.
Is this normal?
Is this normal?
Hi, the serial number is hq22036yxgd.
Hi @intersup
This serial is correctly registered for a 12|12|30 DCDC charger as can also be seen from Part No on the Victron support page. The answer below from Matthias is correct in this case in that the support page only shows an example image from the product group and not the exact product.
Kind regards,
Thiemo van Engelen
It sometimes only shows the product category not the exact product and in that case it's possibe that the picture doesn't match.
It also shows the product number and that you can use to check with the price list:
It's not normal, though not necessarily unheard-of - very occasionally the lookup tables for the serial numbers can get a little glitched.
But also -and this may seem a silly question, but bear with me- are you certain you have a 12/12-30? I've seen about half-dozen instances this year alone where someone inadvertently had a different unit than they thought, thus why I have to ask.
Yes I am sure that I have 12|12 - 30 as shown in the attached photo.
Is there any possibillity I have 24|12 - 30?
Victron - Where to buy - Authorised Installers, Sales and Distribution
40 People are following this question.
