xtra-raum avatar image
xtra-raum asked
How can i improve the efficiency of the battery charging (AGM) with my EasySolar system?
Equipment: 1 x EasySolar 24/3000/70-50 Color Control GX; 2 x AGM 110 Ah 12V; 4 x PV Panel 330 Wp; Grid connected
Settings: EES with feed-in excess solarcharger power, phase compensation; min SOC 20%; Batterylife state: self-consumption; Grid setpoint 0W, scheduled charging disabled
Situation:
I have just checked the data of the first 2 weeks of operation: I have
- solar production: 79,5 kWh
- direct use of solar: 17,5 kWh
- solar to batterie: 25,5 kWh
- solar to grid: 36,5 kWh
- total consumption: 37,0 kWh
- direct from solar: 17,5 kWh
- from grid: 1,5 kWh
- from batterie: 8,0 kWh
So I put 25,5 kWh into the batterie and got only 8 kWh out! This is a poor efficiency of ~ 30%!
Is there any change in the settings possible to improbe this rate?
battery chargingEasySolar All-in-One
xtra-raum avatar image xtra-raum commented ·
sorry no typo. The 8,0 kWh deliverd from the battery is correct!
Here are some more information from the settings in the VE configure:
General tab:
- enable battery monitor: selected
- Battery type: Gel/AGM, Victron Energy, Gel Exide A200
- state of charge when Bulk finished: 85%
- battery capacity: 110 Ah
- charge efficiency: 0.80
Charger tab:
- Enable charger: selected
- Storage mode: selected
- Charge curve: Adaptive + BatterySafe
- Absorption voltage: 28.80 V
- Float voltage: 27.60 V
- Charge current 52 A
- Repeated absorption time: 1.00 hr
- Repeated absorption interval: 7.00 Days
- Maximum absorption time: 8 Hr
ESS Assistant:
- Battery system: System uses Gel or AGM batteries
- The battery capacity of the system is : 110 Ah
- Sustain voltage during first 24 h of sustain: 23.00 V
- Sustain voltage after 24 hours: 25.00 V
- cut off voltage for a discharge current of: 0.005 C = 24.00 V; 0.25 C = 23.30 V; 0.7 C = 22.80 V; 2 c = 22.40 V
- inverting is allowed again when voltage rises : 0.60 V above cut-off(0)
- Are there PV inverters connected on the AC out of the Multi/Quattro system?: No
JohnC avatar image
JohnC answered ·
Hi XR. I note too that your consumption figures don't balance. If that 'from batterie' figure was 18.0 instead of 8.0 it would. And would also give you ~70% batt efficiency, typical of what I see with Pb's.
Clerical error? Maybe not, but needs asking.. :)
