kta22 avatar image
kta22 asked
Victron MPPT RS 450/200 current overshoot
Hi, I'm having this Victron configuration : 2x Multiplus II (5000VA) single phase ( parallel) + mppt
rs450/200 + cerbo gx + Lifepo4 560Ah + smart shunt which is working good. I've activated DVCC function in Cerbo GX, with a low 26A battery charging current, but when I'm having a transition from inverter high load to low load (e.g. from 7.2kW to ~0.2KW), the charging current overshoots up to maximum value I've set into mppt (150Ah) and not stays at 26A. Is like DVCC function is shunted for couple of seconds and current is coming down to 26A slowly ( 150A -> 26A in ~5sec) afterwards. Are you aware about this issue ?
mppt rs
