DML DML avatar image
DML DML asked
U charge lithiums on my multiplus. Possible and how?
Hi all. Looking to install 3x 130ah lithiums non victron to replace my dying lead acids.
I have a multiplus and solar mppt and want to swap out and run off lithium instead.
The batteries will be stored on board regarding temperature. Spoke to victron uk and here I am.
Is this a pipe dream or is it possible and what who and how would this be acheiveable.
Thanks to all. Eagerly looking forward to any insight..
Lithium BatteryVE.Direct
Justin Cook avatar image
Justin Cook answered ยท
Literally no problem with this; the ease of setup will depend on which lithiums you use, specifically if you're using drop-ins or component cells that require a separate BMS.
If you're using drop-ins like Battle Born (Firefly) or Victron's drop-ins or any number of others, it's literally only a matter of changing the charge profiles of your MPPT and your Multi to match the manufacturer specs of your lithiums (though the default lead-acid profile in the Multi is frequently a great match for lithiums, it just depends on the brand and etc.)
If you're using component cells and a separate BMS, there's an added degree of complexity in programming because you just have to make sure that all the components are talking to each other, and the degree of complexity depends on the battery specs and the brand of BMS and etc.
Ultimately, though, the answer to this is simply a resounding yes. This is not only not a pipe dream, this is actually very common practice. Depending on where you are, you can give us a call here in San Diego for Battle Born pricing, but you may well be able to find them somewhere closer to your current location, and in reality there are several other brands of drop-in lithium battery that are excellent as well; of course, this being a Victron forum I would be remiss if I didn't mention that we can get you Victron drop-ins or component lithium systems too, though the specs are different and don't meet everyone's needs.
DML DML avatar image DML DML commented ยท
Very encouraging and many thanks for making time to reply. I have the following batteties
Many thx
0 Likes 0 ยท
DML DML avatar image DML DML DML DML commented ยท
Please see attached
0 Likes 0 ยท
