kudos50 avatar image
kudos50 asked
MPPT RS450 interrupts charging process at about 97%
Re-post from the DESS release thread:
My MPPT RS450/100 temporarily interrupts the charging process when the battery is near full.
I have a large pack so the Multi's are still charging 2kW at that time but the MPPT RS stops for a few minutes before continuing. Before and after that one stop, all is working fine. Either help charge the remaining % or invert.
So far, it takes about 5mins to recover. Ramping down the panels. Turning to -10W for a while. And firing everything up again.
Can not be sure but it seems to be related to the switch from bulk to absorption charging. For both AC-PV as well as DC-PV feed-in to grid is enabled. I'm using DVCC with 40kW of Pylontech packs.
mppt rs
6 comments
Charge rate is dictated by the batteries. They also report SOC. And Pylontechs certainly reduce the charge current setting as they get closer to 100%.
Guessing the GX cuts the big charger first.
It would be interesting to see a graph showing the charge current and the charge current limit. You can do this with a custom widget in the advanced section of VRM. You'll find the metrics under BB artery monitor.
kudos50 avatar image kudos50 kevgermany ♦♦ commented ·
Multi's are still doing 1500W when MPPT RS has reached 0. The thing I do not understand is that DV-PV feed-in to grid should always keep maximum power point. Why is not simply inverting etc.. The system has more than enough capacity to invert all DC-PV.
<edit> please don't mind the increased output after the interruption. Way too many clouds at that time to state that ramping down started 10mins earlier.
Alexandra avatar image Alexandra ♦ kudos50 commented ·
How far apart are the logs?
kudos50 avatar image kudos50 Alexandra ♦ commented ·
Not sure I understand your question. Logging interval from Cerbo to VRM is set to 1 minute which I think is the minimum value.
If I check HomeAssistant is says the 0 charge took about 30 second this time but I have had longer periods (~5mins) over the last few weeks.
DESS does not alway plan a 100% SOC so it depends when it last happened. Will check for some more examples.
April 7th
Longest one I could find was 23rd of march in de late afternoon
