The battery description is as follows: Ecco 51.2v 100ah 5.12kWh Lithium Battery W51100 Wall-Mounted.
Officialy not, see:
https://www.victronenergy.com/live/battery_compatibility:start
But maybe someone with experience with these batteries can give you a better answer
According to the company selling them (solarwarehousesa) they are compatible with Victron.
A lot of these type of batteries from companies no one has every heard, of tend to use a third party BMS, Pace being one of the most common. So they should pass enough information to the cerbo to enable correct operation (DVCC limits etc), but they may not pass as much additional info as some of the supported batteries do, such as highest/ lowest individual cell voltage etc.
60 People are following this question.
