Hi community,
After install SetupHelper,GuiMods,RemoteGPIO, from GitHub, cannot enable RemoteGPIO, under Settings/I/O/RemoteGPIO, thanks in advance for any help!
Hi community,
Firmware version etc?
Which mod did you use, what device are you running it on?
Hi Alexandra,
Thanks for Your answer, the device is Cerbo GX with version 3.30, add some pictures
Have you tried rebooting the device? If you have terminal access you can check the logs and see if there is anything there.
cat /data/log/rgpio_driver/current
Hi Derrick,
Thanks for the answer, "yes" reboot more than once, I'll try to check the logs.
Hi Alexandra and Derrick,
After uninstalling and installing again, reboot, and everything works fine. Thank You both for Your support. Is there any possibility in the Cerbo GX of assigning a function and conditions of different sensors, for example temperature, as with the internal relays, at the moment it is only possible to use relay 1 or 2 that are previously assigned, will it be possible to assign any of the external ones? Thanks in advance.
Hi Derrick,
You're absolutely right, but I have node red disable because it causes the Cerbo gx to go into overload, is there any way to alleviate this situation which I don't think is unique?
It's close to the hypothetical scenario you mentioned, it's an excellent guess, I'll follow the procedure to see what happens, very good, thanks
64 People are following this question.
Automatic Data Logging SmartSolar MPPT 75/15
Is it possible to load Data to VRM - for example power consumed by car?
Missing data in API and VRM portal export
no solar history in VRM - actual mqtt-pv-inverter data is shown
Any thoughts on creating a new HTML "Remote console" using Canvas & Javascript (via Modbus)?
