nordpv avatar image
nordpv asked
no solar history in VRM - actual mqtt-pv-inverter data is shown
Hello!
I'm using Cerbo GX with Multiplus II 5k and some pylontech batteries as ESS AC-parallel.
PV-Inverter is Kostal Plenticore on AC-In (parallel to Multiplus II). To see pv-inverter data in cerbo (and VRM) i'm using https://github.com/mr-manuel/venus-os_dbus-mqtt-pv .
Actual power is correctly shown on both (cerbo and VRM), but there is no (historical) energy data shown on VRM...
Is it possible to get this data added?
Ove
VRM
Hi @NordPV,
I think this is an issue with how that 3rd party code writes to the dbus. You're probably best starting a ticket in their GitHub and hopefully the author can resolve it.
nordpv avatar image
nordpv answered ·
what data is additionally needed by the VRM ?
Actual power is sent every 5 seconds...any more info needed ?
There is a brief specification of what is expected here, looks like the AC/Energy/Forward kWh data is missing
https://github.com/victronenergy/venus/wiki/dbus#pv-inverters
Here is another implementation for different devices that I believe work correctly - https://github.com/victronenergy/dbus-shelly/blob/9b3696da597b41ab23e117b245cd09b9469157bd/meter.py#L95
https://github.com/victronenergy/dbus_vebus_to_pvinverter
But from here the solution should really be explored on the GitHub for the modification you are using, this is not a VRM issue.
nordpv avatar image
nordpv answered ·
solved...
i had to add an additional measurement to my NodeRed Flow:
now - i see solar-data in VRM
Thank you!
Ove :-)
