javierag avatar image
javierag asked
VRM API Error 401 - invalid token
Hi!
I am working on a small project where I try to connect to a Victron Venus GX using VRM API. My code (in Python) is the following:
import requests
import json
login_url = 'https://vrmapi.victronenergy.com/v2/auth/login'
username = "aaaaa@bbbb.com"
password = "123456"
login_string = '{"username":"'+username+'","password":"'+password+'"}'
response = requests.post(login_url, login_string)
token = json.loads(response.text)["token"]
idSite = "1111111111"
diags_url = 'https://vrmapi.victronenergy.com/v2/installations/'+idSite+'/diagnostics'
querystring = {"count":"1000"}
headers = {
"Content-Type": "application/json",
"x-authorization": "Bearer <"+token+">"
response = requests.request("GET",diags_url, headers=headers, params=querystring)
print(response.json)
print(response.text)
I try this script but the response I get is like:
<bound method Response.json of <Response [401]>>
{"success":false,"errors":"Token is invalid","error_code":"invalid_token"}
Any idea and/or can someone support me?
Many thanks in advance
JavierAG
errorapi
Hi @JavierAG
There are quite a few existing posts regarding 401 API errors, some containing good info.
If you have already checked them, please include that so the existing solutions can be ruled out
javierag answered ·
Thanks for the advice, I could find some errors on my code. I add the new code with some insteresting changes:
import requests
import json
loginUrl = "https://vrmapi.victronenergy.com/v2/auth/login"
password = "123456"
loginString = "{\"username\":\""+username+"\",\"password\":\""+password+"\"}"
responseLogin = requests.post(loginUrl, loginString)
dataLoginRequest = json.loads(responseLogin.text)
token = dataLoginRequest["token"]
idUser = str(dataLoginRequest["idUser"])
instUrl = "https://vrmapi.victronenergy.com/v2/users/"+idUser+"/installations"
#querystring = {"count":"1"}
headersInst = {
"x-authorization": "Bearer "+token
responseInst = requests.get(instUrl, headers=headersInst)
print(responseInst)
print(responseInst.text)
dataInst = json.loads(responseInst.text)
if dataInst["success"]:
for installation in dataInst["records"]:
idSite = str(installation["idSite"])
print(idSite)
diagsUrl = "https://vrmapi.victronenergy.com/v2/installations/"+idSite+"/diagnostics"
querystringDiag = {"count":"1000"}
headersDiag = {
responseDiag = requests.request("GET",diagsUrl, headers=headersDiag, params=querystringDiag)
print(responseDiag)
print(responseDiag.text)
Many thanks for the advices again
JavierAG
