muammer avatar image
muammer asked
can we connect the 36V mppt to Cerbo?
We use the 36Vdc Minn Kota and solar panel for the Minn Kota batteies on the boat. we also charge the 36V batteries with 150/35 MPPT. We want to use Cerbo GX on the boat but service voltage is 12V. When we connect to 36V MPPT to Cerbo GX, it will be problem for charge algorithm of the service batteries.
cerbo gxvoltage
Alexandra avatar image
Alexandra answered ·
@muammer
What do you mean it will be a problem?
The Cerbo needs a power supply. It can use anything from 9v to 70v. So connect that somewhere.
The mppt can charge the 36v. Nad be connected to the GX for reporting. Not a problem. Do you have balancers on the battery or is it one unit?
