airstreampictures avatar image
airstreampictures asked
Issue with MultiPlus 3K config for Victron batteries
I’m having a MultiPlus 3K 120 configuration problem… I’ve just finished the build of a lithium system for my Airstream, and am having a configuration issue I can’t figure out.
The system is all-Victron, with 3x200Ah smart batteries, Lynx BMS, the Multi, an MPPT 150/35 solar controller, DC/DC and Cerbo. When I turned the MultiPlus on, it worked perfectly, and immediately began charging. Its defaults were the wrong battery type, so I went in with VE.config and changed it to Victron LiFePo controlled by BMS, which brought up all the (apparently) proper charge settings. But as soon as the Multi reset after uploading the settings, it threw up a low battery warning (the batteries are all at 13.45V) and a VE bus error #15. (I made no other changes to the config except to limit the AC input amperage to 16.)
Resetting the Multi to defaults makes the errors go away.
Any idea what might be going on?
VEConfigure 3lynx bmssmart lithium
Do you have the Lynd BMS connected to the Cerbo?
airstreampictures answered ·
I found the solution. For the benefit of anyone else who runs into this, if you have any other BMS than the Victron VEbus BMS, DO NOT choose the battery type ‘Victron Smart LiFePo with VE bus BMS.
I assumed that it was the right choice for any BMS that used the VE bus to communicate (like my Lynx BMS), but it’s not. It’s a specific setting for the VE bus BMS and raises all kinds of issues with other setups.
Once I got that sorted, it all worked like I dreamed it would.
VEConfigure manual
VEConfig alternative method for VE.Bus using VictronConnect
LED indications, warnings, alarm and error codes
Lynx Smart BMS product page
Lynx Smart BMS online manual
