Noel Rath avatar image
Noel Rath asked
Orion TR 12/12 30A absorption mode
I have a Victron Solar Controller, Victron Smart Shunt with temperature sensor, Victron Blue Smart Charger and Orion TR non isolated.
I did have a Redarc 1240D but it was always in absorption mode. I replaced it with an Orion TR 12/12 30A.
The Orion goes into absorption mode almost immediately.
Help please.
I have two VoltX 200 AH batteries in parallel 5 metres from the Sprinter 2016 battery and alternator. The cables are 2AG for red and 3AG for ground.
The voltage reading measured with a multimeter at the Orion input and output terminals to ground is .15volt less that the Orion TR reading.
victron communitysupport
klim8skeptic avatar image
klim8skeptic answered ·
@Noel Rath You have 1.2v drop between the Orion and the SmartShunt.
Check your cables, connections, earthing and fuses / breakers for the voltage drop.
Noel Rath avatar image Noel Rath commented ·
Thank you very much
Thank you very much for your quick feedback. From your advice I found the problem and all is working perfectly now.
Noel Rath answered ·
img-1974.pngimg-1975.pngimg-1976.pngimg-1977.pngimg-1978.pngFurther to my previous post. Here are some images.
Philip Kamau avatar image
Philip Kamau answered ·
Double-check all your wiring connections to ensure they are securely connected and properly routed. Any loose or damaged connections could affect the very small voltage drop, While a small difference is expected due to measurement accuracy and resistance in the cables, a significant difference from my experience has been sometime compounded by the connections, in some cases using lugs at termination points (if not installed) has been helpful.
jbourdon avatar image
jbourdon answered ·
hey guys, just a heads up:
i changed my lipo battery 2 weeks ago. roamers 200Ah gen1 to 230Ah gen3. before and after was working fine: 100% charge at 30A then a few days ago i updated the firmwares of my all my victrons (ACDC, DCDC, solar, BMV) until then batteries charged to 100%. since they only charge to 80% from any charger.goes into absorption way too early. i did a bit of investigation (cabling, talked to Roamers, settings of victron devices) nothing obvious. I really suspect a bug in recent firmware. 90% confident :-( I will try to post screenshots tomorrow. could you take a look please? thanks
jbourdon answered ·
Actually is there a way to move back to older fimwares, like last of 2023 for example?
jbourdon answered ·
as promised, some screenshots, let me know if you spot something i didn't seescreenshot-20240414-152820-roamer-bms.jpg
Victron - Where to buy - Authorised Installers, Sales and Distribution
Warranty and Repairs.
