brett-t avatar image
brett-t asked
Touch 50 Cut Out
I am installing a Cerbox GX and a Touch 50 into my boat. The Touch 50 will replace the Digital Multi Control on my Control Panel. I am a long way from the boat and I want to decide how to mount the Touch 50 and so decide which mounting kit to buy or to use the one that comes with it.
I cannot find a complete diagram for the bracket that comes with the Touch 50.
I want to know if it will fit over the cut-out for the Digital Multi-Control
I have the diagram below which shows the outside dimensions of the bracket but I can't find one with a measurement of the cut out hole in the bracket.
Diagram of Touch 50 Bracket (I think)
So I know it is 128mm x 87mm, but I want to know what the size of the hole is (assuming it is central in the bracket)
I have a diagram of the bracket for the DIgital Multi-control,from this post
https://community.Panel cut out dimensions for digital multi control
so I can assume what I will need to cover
Does anyone have these dimensions?
cerbo gxtouchscreen
ejrossouw avatar image
ejrossouw answered ·
brett-t answered ·
I am sorry the links I inserted did not seem to work. They seemed to when I created the post.
Here they are with the URLs
https://cdn.competec.ch/documents2/0/0/5/195113500/195113500.PDF
https://community.victronenergy.com/questions/6639/panel-cut-out-dimensions-for-digital-multi-control.html
