Is there a quick way to disable the temp controlled relay #1? Thanks, Bill
On the Cerbo, I am using relay 1 to control some fans based on temps, but there will be times I do not want them to run as I will be traveling and they would pull in very hot air from the engine if they run. So hopefully I can do it from vrm or even the web console. -Bill
From the VRM it is easy as the side bar has links. Relay 1 and relay 2
42 People are following this question.
