Can any of the victron Lithium batteries work with Outback MPPT chargers?
The Flexmax will charge the battery, but you'll need some way of interfacing the Victron BMS (which you'll need when using Victron batteries).
You'll need to somehow communicate with the Flexmax to tell it to stop charging when the BMS needs it to.
I don't know what sore to interfaces are on a Flexmax charger, so I can't advise on this. I presume the Outback chargers can be configures to charge lithium chemistry?
10 People are following this question.
