Will a Multiplus2 S/N HQ 2236YTJF7 work in parallel with a Multiplus2 S/N HQ 23147UFMF when both updated to the same firmware version? Thanks.
Hi, yes since there not far apart it will work
Parallel can always be a bit tricky
Follow this guide and it should be ok
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
It's a matter of hit and miss. My 2 Quattros are 4 years apart but surprisingly, they work fine. My Victron agent looked at the chips of the 2 inverters and concluded that they would work. They are running the same firmware version. The imbalance is merely 3%-9% depending on the amount of loads. I was targeting 10% so I'm very happy without having to do anything. Some people here have problems even when their inverters were manufactured in the same week.
F.
41 People are following this question.
