My loads max out at around 150amps but mostly around 50amps. İs it ok to use the 250amp.mega fuse for the main fuse on the lynx shunt?
The Lynx uses a CNN fuse type. I think the dimensions are a little different, so no. You can find some class t fuses that fit there as well. Basically is needs to match the dimensions. CNN dimension is the top picture.
47 People are following this question.
Lynx Shunt VE.Can installation
hey all, cant get ve bus to appear/be detected
LYNX VE.CAN-Shunt: Location of the configurable onboard relay
Will the Fuse LEDs on Lynx Distributor illuminate without the 4-pin cable supplied with unit?
Lynx Shunt VE.CAN Battery Status PGN for Batt Instance 0 not transmitted.
