Hello Vicron comunity
I want to protect the life time of my HE batteries at best.
We use them in default mode.
I read that I could unload them at 0%.
But what is the optimum level of discharge to maximize lifetime? 20% / 25%?
thank for your help
thank for your help
Hi @LE BEL
Depending on the use of the batteries (are they mostly fully charged, or cyclic use, etc)
the most life-extending is to not charge to 100%, the batteries are on default not charged to the max, but you'll win most by charging to even less voltage, like 27,5 volt.
keeping discharge levels above 10-20% SOC will also help, but mostly only when they stay at these levels for longer times.
Hi Daniël
Thanks a lot
It's a cyclic use in a boat.
For the discharge level, Is this true for all lithium batteries or specifically for Lithium HE?
Best regards
yes on the discharge levels, note that different manufacturers might have different '0% SOC' levels, some might have a built-in reserve, some might actually be empty at 0% SOC
Thanks,
Yous said that 0% soc could be intégrate built-in reserve depending of manufacturer.
Is it the cas of VICTRON Lithium HE ?
If yes what is the built-in reserve à 0% SOC ?
Best regards
They are pretty much empty at 21 volt, I don't know the corresponding SOC value from the bms
I suggest you have a thorough read through these pages:
Those articles are about LiFePO4 batteries, a different chemistry then the HE batteries, and not applicable.
11 People are following this question.
