If I add the Lynx shunt to my system, will it provide a reliable SOC value that can be used by the rest of the system instead of the (completely unreliable) value from my BMZ ESS?
Many thanks...
Many thanks...
I don't know what a BMZ ESS is, but if you mean a BMV-712, then it most likely hasn't been connected properly into the system or hasn't been programmed appropriately for your battery bank, since the BMV series are some of the most accurate battery monitors on the market at any price point... and a different battery monitor wouldn't resolve those issues if they exist.
I'd suggest revisiting your existing battery monitor installation and programming and correcting -or having a professional correct, if it's not within your own scope of familiarity- anything that's amiss there before trying anything else.
bmz is my battery manufacturer...
my question was whether the soc value produced by the lynx shunt can be internally used by the system in places where soc must be specified, instead of the value supplied by the battery bms.
45 People are following this question.
Lynx Shunt VE.Can installation
hey all, cant get ve bus to appear/be detected
LYNX VE.CAN-Shunt: Location of the configurable onboard relay
Will the Fuse LEDs on Lynx Distributor illuminate without the 4-pin cable supplied with unit?
Lynx Shunt VE.CAN Battery Status PGN for Batt Instance 0 not transmitted.
