ms5 avatar image
ms5 asked
vrm portal display and synchronization issues
The question i have is that i’m trying to read certain values from the DSE panel to a victron cerbo gx over ethernet com. I have most of the readings from the dse panel i.e volt and amp. And it seems as if values will not show itself in the victron controller, if it doesnt show in the DSE scada (monitoring). And the onle value i’m missing is the kw.
What’s weird is that i am getting a total kw from the DSE panel which is normal, but i cant get the kw reading over to the victron interface, even though i'm that the interface can tell that the generator is activated. The dse controller does not read kw over each phase since the genrator is wire in delta. I have 3 quattros each phase. Its hard to so say how everything translates over.
As you can see above, it does store and read the generator performance, but i would like to see this live as well.
It would show up something like this (above) when load is coming from the generator.
In the remote controller, it reads the voltage and amp from the dse controller, but not the kw.
above shows what the quattro readings when on generator load (Another test from another period). And with the image underneath shows a side by side comparisone directly from dse controller up with what the quattro 48/5000/70-2x100 120V page. They have their own messurements which make sence, but does this effect the synchronization as they differ abit in values?
And if so, is there a way to my bypass this?
vrm advanced
