Please i need an explanation as to what VE.bus inverter state "255" mean and also what MPPT state "131" is?
Hi, the 255 most likely means “unknown”. Perhaps it is switched off then; or communication issue.
131 mppt I dont know; far higher than the range I’m familiar with.
MultiPlus Product page / Quattro Product page
MultiPlus 230V Manual / Quattro 230V Manual
MultiPlus 230V Datasheet / Quattro 230V Datasheet
VE.Bus Error codes / VE.Bus configuration guide
11 People are following this question.
Large difference between solar blanket voltage output and Victron dashboard
Why MPPT sizing system is recommending 150/35 and not 100/50 ?
Are 50vdc solar panels wasted on a 12vdc system?
SmartSolar MPPT 150/85 VE.Can - No current flow in Bulk with PV at VOC
Victron Multiplus 3000/50/12 not utilizing supplied solar to power or charge when inverting
