sv-soleil avatar image
sv-soleil asked
mcp3208 ADC raspberry pi
Here are step-by-step instructions on how to interface an mcp3208. I spent days following old posts and falling down various rabbit holes. What a nightmare. What I’ve done below works as of 2024.
Step 1: download anyspi.dbto
cd /u-boot/overlays
wget https://github.com/raspberrypi/firmware/raw/master/boot/overlays/anyspi.dtbo
Step 2: create run files
cd /opt/victronenergy/dbus_adc
mkdir service
nano run
#!/bin/sh
exec 2>&1
exec softlimit -d 100000000 -s 1000000 -a 100000000 /opt/victronenergy/dbus-adc
(Add above lines to the file “run”)
cd /opt/victronenergy/dbus_adc/service
mkdir log
nano run
root@raspberrypi2:/opt/victronenergy/dbus-adc/service/log# more run
#!/bin/sh
exec 2>&1
exec multilog t s99999 n8 /var/log/dbus-adc
chmod 755 /opt/victronenergy/dbus-adc/service/run
chmod 755 /opt/victronenergy/dbus-adc/service/log/run
ln -s /opt/victronenergy/dbus-adc/service /service/dbus-adc
Step 3: Add one line to /u-boot/config.txt
nano /u-boot/config.txt
(Add this to the end of the file)
dtoverlay=anyspi:spi0-0,dev="microchip,mcp3208"
Step 4: create your own dbus-adc.conf file
nano /etc/venus/dbus-adc.conf
Here you need to put your own custom information, for example:
device iio:device0
vref 1.8
scale 4095
label "Tank 1"
tank 4
reboot
On your remote console go to
Settings->I/O->Analog Inputs
tank monitoranalog
tadpole48 avatar image tadpole48 commented ·
I think I managed to work out the errors in the original instructions, I hope you don't mind if I re-list it with my interpretation...
Step 1: Download anyspi.dbto
cd /u-boot/overlays
Step 2: Create run files
cd /opt/victronenergy/dbus-adc
mkdir service
cd service
nano run
add these 3 lines to run file (then exit Nano with save)...
#!/bin/sh
exec 2>&1
mkdir log
cd log
nano run
#!/bin/sh
exec 2>&1
Step 3: Change "run" files Permissions
Step 4: Create a Symbolic Link pointing to the new service folder in the /service/dbus-adc folder
Step 5: Add one line to /u-boot/config.txt
add this 1 line to the end of the config.txt file (then exit Nano with save)...
Step 6: Create your own dbus-adc.conf file
device iio:device0
vref 1.8
scale 4095
label "Tank 1"
tank 0
label "Tank 2"
tank 1
label "Tank 3"
tank 2
label "Tank 4"
tank 3
label "Temp 1"
temp 4
label "Temp 2"
temp 5
label "Temp 3"
temp 6
label "Temp 4"
temp 7
I'm in a similar position, but struggling with the "what works" above, I noted a couple of errors above with the use of "_" instead of "-" (Step 2 cd /opt/victronenergy/dbus_adc should be dbus-adc) and I do not appear to have the same file structure, when finished with the above my directory tree is different, I don't know where I went wrong!
Should the line "root@raspberrypi2:/opt/victronenergy/dbus-adc/service/log# more run" really be in the log/run file?
Any help would be much appreciated.
GX Tank 140 product page
Connecting tank monitoring to Cerbo GX
