brian-kelly avatar image
brian-kelly asked
BSLBatt Victron settings for low soc.
I'm having difficulty finding an answer to my question. We are planning to connect a BSLBatt lithium bank into the VE.Can port of the Cerbo, and then link the Quattro through VE.Bus. I need guidance to set up a relay to trigger an alarm in the virtual assistant. The parameter for the alarm would be low SOC, and I need to confirm if the Quattro will have the proper SOC from the BSLBatt lithium. Thank you.
virtual switch
nickdb avatar image
nickdb answered ·
Please read the Victron/BSL setup doc and the manual for the Cerbo, it has all this information.
Batteries, also, do not connect to VECAN, there are dedicated BMS ports.
https://www.victronenergy.com/live/battery_compatibility:bsl
You will have to decide what is your idea of low SOC as well as well.
Low SOC (and potential shutdown) for BSL is 10%. See the set up docs they provide or Victrons guide.
Are you using conditional AC connect rather than ESS?
Fideri avatar image Fideri commented ·
I think some Cerbos have 2 VE.CANs (1 for the battery) in place of a VE.CAN and a BMS.CAN. Mine has a BMS.CAN, so I use that for the battery.
F.
brian-kelly answered ·
Thank you for your replies. I will be setting the low SOC at 20%. I am more looking at setting up the relay. I will look into this further.
VE Configure/Virtual Switch
Ignore AC input using the Generator Assistant
